Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
A
Anonymous Posted on May 31, 2014
Where is located the alternator poulan pro pd24ph42st
Robert
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jun 19, 2016
Robert
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
546
Points
Just about all the smaller type engines the alt. can be found under the flywheel. The alt is a combination of both the flywheel and the stator ( the electrical windings ) atached to the engine block under the flywheel. Watch out...if you use a vehicle to jump your tractor, it will fry the stator if you the jumper cables on after it initially starts!
1helpful
3answers
Poulan Chain saw pp6120, 2006, Type MS 60, Engine Code CS 59 05 A
poulan suppliers are available at heidleberg mowers ,burwood mowers, speedie mower service , the red shed, clayton mowers, mowers galore, melbourne farm supplies diamond creek machinery croydon mower power
and that is in melbourne alone
I see that poulan and husqvarna are the same show so check out your local husqvarna dealer as well
go google and type in --poulan equipment distributors in victoria australia and the first site is poulan pro--lawn and garden machines
search other sites that show up
3helpful
My battery keeps going dead on my poulan pro 500ex rider i already replaced the battery 4 months ago and its dead again.
Not too surprising. Unless you use it very often, the battery will go flat fairly easily. Was the old battery tested to have failed? It is possible you have a bad alternator or connection to the alternator. An easy way to keep your battery is with a float charger; it keeps the battery charged to perfection and ready to go. I have no power to my shed, so I use a solar one. It cost about 34 dollars at Harbor Freight (.com) Farmerbear at FixYa.com
1helpful
Poulan pro lawn mower starts & dies
unless this mower is older then i am, it has no points or condenser. It has only a magnito. Sounds more like a plugged up carberator.
Apr 30, 2010 • Garden
Trying to change alternator for riding mower poulan pro
thats under the fly wheel are sure thats what yor trying to replace its not to hard if you have the tools
Where is the air filter located on the poulman pro 6.75 ready sta
it is either on the handle up near the top which they call a snorkle filter or on the side of the carbi in a square plastic cover
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
