Allen & Heath Xone:92 DJ Mixer Logo
E
EURIS Posted on Jun 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CHANNEL MONTIOR LIGHT WILL NOT STOP FLASHING - Allen & Heath Xone:92 DJ Mixer
Glen
Level 2:
  • Expert 225 Answers
  • Posted on Jun 04, 2014
Glen
Expert
Level 2:
Answers
225
Questions
0
Helped
82225
Points
395
You've pressed the "solo" button by accident.
Pmp500 mixer desk 8 channels
The flashing green light on your Behringer Pmp500 mixer desk indicates that it's receiving a signal, but it's unclear why the first 4 channels aren't working. Make sure that all cables and connections are properly secured and that the power supply is adequate for the mixer's needs. If the issue persists, you may need to consult a professional for further troubleshooting or repair.
Feb 14, 2023 • The Music
How do I plug mixer into pa speakers, monitors, instruments
Without knowing what make and model of the gear you're looking to connect, I can't give you a definitive answer. However, in general, if you have a powered PA mixer, meaning it has both a mixer section and a power amp section in a single box, the main speaker outputs will be on the rear panel of the box and marked as such. There will also be a jack for monitors, but some mixers have an amp for monitors, some just have an output for the monitor mix, but not an amp for them, and on some you can switch the main outputs to feed either a Left and a Right speaker, or a front mono speaker and a montior speaker. Instruments will go into the individual channel inputs.
Feb 08, 2015 • Music
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Flashing lights
Were you able to get this fixed? I've been having the same issues and the Fishman support team's instructions for cleaning the pots didn't fix it.
Blinking standby light no power
When you turn the amp on, does all the tubes light up? please add more info to help you out.
1helpful
My chauvet Elan stopped working. I cant find a power switch and am not even sure how to check whats wrong
"Elan stopped working doesn't give us much to go on... does it light? Do you hear anything in it? Are you activating it from DMX or as standalone?
Hi , I wonder if you could shed some light on a problem my son has with his behringer pmh3000 amp. With the digital effects set to any number it constantly reverts to 1. Also when effects are turned on...
You say lights flash? There are a lot of LED's on the unit and there are displays. Depending on what you mean by "lights" sends us on a whole different path. Remeber the effects ADD to the noise as they add into the buss to the amps. You should have the Effect to MAIN knobs not too high... say 12 o'clock. Same for the effect send knobs for the channels. If all the LED's flash, better stop using the unit as there is a power supply problem and damage will occur.
Please read my tip on here about the hazard of Channel A output when using Speakon to 1/4 inch speaker cables or adapters. The SHELL or SLEEVE of channel A cable is the HOT one, NOT the tip so never let that shell touch or connect to ground. The effect window when first powered should display a zero, not one... If it displays 1 at first, unit needs to be taken for repair as there is a defect.
Connect ALL interconnected equipment to the same receptacle or power conditioner source. Pro's run extension cord back to mixer if they have other stuff on stage. The speaker cables should connect to NOTHING other than speakers... do NOT try to tap off the daisy chain outputs of speakers for anything other than speakers. Use balanced lines and isolating DI boxes to avoid ground loops. Make sure to only poower this from a grounded receptacle.
1helpful
Channel sliders will not bring up lights but the flash buttons do work. Only way to get all the lights on at once is to push the Full-on button.
Verify that you have a terminator resistor at the end of your DMX cable of there are several units daisy-chained. The resistor prevents digital signals from reflecting causing confusion of the data stream. Read up on DMX termination via google.
I have a Mackie cv1604 which suddenly stopped working. all lights on the channels light up and no sound. help?
same problem here.. gimme a holler if you've figured anything out.
mine, channels light up, it's getting sound (input) from mics, but it's no sound coming out. i'm almost definite the problem is with the main mix slider. but then again i could be wrong.
Top Allen & Heath Music Experts
Don A
Don A
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you an Allen & Heath Music Expert? Answer questions, earn points and help others
