HP PSC 1410 All-In-One InkJet Printer Logo
A
Anonymous Posted on Jun 02, 2014
HP deskjet 1512 says out of paper and its not
honey
Level 3:
Master:
  • HP Master 262 Answers
  • Posted on Jan 31, 2018
honey
HP Master
Level 3:
Master:
Answers
262
Questions
Helped
320261
Points
1535
There might be driver or Hardware Issue in the printer you should try to reinstall the drivers for the printer Support For Hp Printer Call Toll Free 877 690 9305
How do you replace ink cartridges HP 61
http://replacethatpart.com/tag/hp-61/
or
http://replacethatpart.com/2014/12/25/how-to-replace-an-empty-ink-cartridge-in-the-hp-deskjet-1512-inkjet-all-in-one-printer-series/
How to install ink cartridge in deskjet 1512 copier/printer?
when you open the door to install the cartridges , hp normally have a decal showing you how to remove and install on the inside of the door
other than that go google and type in --user manual for HP deskjet 1512 printer/copier --
look for the pdf download version
How do you connect a hp deskjet 1512 to a rca pro10 tablet
If it supports the printer with an OTG cable, then use one.
Unexpected Paper Size error while printing a3 size paper on HP 9300 deskjet printer
Although you have selected the paper size A3 your printer HP Deskjet show unexpected paper size.....
1. clean the carriage area ...........
2. change the carriage sensor....... If not solved
3. you need to replace carriage unit.
Thanks
HP Deskjet 690C says it is out of paper when it isn't.
Pretty well all printers come with two places to load paper: one paper tray and one feed tray.
Is the button on your computer or the setting in your word processor teling it to load from the other tray?
IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
17helpful
7answers
Brother MFC-240C Change Unable 50
I also had this problem, your solution was spot-on, remove the top cover and control panel and re-seat the encoded strip. simple.
boy, are you guys good.
k24674
Grand Canyon Tech
Grand Canyon Tech
