Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
A
Anonymous Posted on Jun 02, 2014
Why wont makita 12v 1201 battery charge? - Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
5 Related Answers
Anonymous
  • Posted on Feb 09, 2009
SOURCE: makita lithium ion 18 v battery wont charge
this normaly happens when the battery has been kept in cold conditions . keep your batteries indoors try sitting them on a radiator for a short period and they should take a charge . cold weather effects the cells in lithium ion batteries .
Robert Koch
  • 165 Answers
  • Posted on Feb 27, 2010
SOURCE: Brand new Makita DC18RA charger wont charge the batteries.
Return to store for replacement.
Repair Ahjoshe
  • 885 Answers
  • Posted on Aug 19, 2010
SOURCE: is it possible to replace the batteries in a 12v m...
Unfortunately there are no repairable parts in a battery. Once a battery is dead it's usually best to find a good recycling center for it, most The Home Depot's have one. Makita lists battery 1234 (Part #193157-5) for this tool but it's the old Ni-MH battery. I'd use battery 1222 (Part #192598-2), it's the better Ni-Cd battery.
Anonymous
  • 312 Answers
  • Posted on Jan 01, 2011
SOURCE: I have a Makita 12v
It sounds like the problem is the battery. It sounds like there are shorted cells in it so that it starts to draw too much current from the charger and the charger shuts down as a safety measure.
I hope this helps,
Happy New Year,
Mark
Anonymous
  • Posted on May 23, 2011
SOURCE: Charger doesn't charge anymore
Can I change the brushes on my 12V Makita Cordless drill Model No 6227D? If yes, how do I do it? Thanks.
Why does my Makita 6011D cordless drill not work when my charged battery in installed? The battery does work on my Makita saw so I know it is not the battery.
Look inside where the Battery terminals connect.
THey are flat metal springs inside the drills Battery hole.
Make sure the are not compressed down causing them not to touch the battery terminals of the battery.
ALso check the Brushes on the drills motor they may need replacing...
Selvol
4answers
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Rebuilding makita battery instructions
Rechargeable batteries are almost never worth rebuilding and never last very long when they are. In some cases, Makita being one, if the circuit board in the battery detects something wrong with the battery, it 'bricks' the battery. This is not resettable and the battery will not charge on a Makita charger. I'd be looking to get my money back from the repairman since his rebuild didn't take.
Switch and bateries
Makita makes two 12V Ni-Cad pod batteries: Battery 1222/2.0Ah (PN: 192598-2) and Battery 1220/1.3Ah (PN: 192681-5). Makita's universal charger (PN: DC1804) will charge any Ni-MH or Ni-Cad pod or stick battery from 7.2V to 18V.
2answers
If you are comfortable with removing the upper half of the housing, unplug charger and remove the screws, take a look at the circiut board for a "cold" solder joint or broken component, usually the round ceramic looking piece with the copper wire around it. but look at the whole board.
2answers
Is it possible to replace the batteries in a 12v makita battery pack
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
3answers
Makita Battery Charger DC18 RA
Maybe your battery is died, you can replace it on
http://www.drillbattery.com.au/buybattery.php/makita_1220_power+tool+battery.html
Jan 20, 2009 • Hand Tools
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
