SOURCE: freezer dying
IS THE FREEZER AN AUTO DEFROST FREEZER? IF SO, IS THERE FROST BUILT UP ON THE BACK WALL? IF FROST APPEARS ON THE BACK WALL, THERE IS A DEFROST FAILURE. THERE ARE THREE ITEMS IN THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL.
THE TIMER IS USUALLY LOCATED ON THE BACK OF THE FREEZER DOWN NEAR THE COMPRESSOR IN THE CORNER. IT HAS FOUR WIRES ATTACHED TO IT. YOU CAN ADVANCE THE TIMER BY TURNING THE KNOB ON THE FACE OF THE TIMER. WHEN IT CLICKS LOUD AND STOPS THE COMPRESSOR RUNNING, IT IS IN THE DEFROST CYCLE. WAIT 5 MNUTES AND CHECK INSIDE THE FREEZER
TO SEE IF THE HEATER COMES ON. YOU MAY BE ABLE TO HEAR THE FROST MELTING AND DROPPING ON THE HEATER. IT WILL SIZZLE AND POP. ALSO, LOOK FOR A GLOWING DOWN AT THE BOTTOM OF THE BACK PANEL.
IF THE HEATER IS ON, THE TIMER IS BAD. IF NOT, CHECK THE HEATER AND BI-METAL.
IF THE COMPRESSOR IS NOT RUNNING, CHECK THE COLD CONTROL TO SEE IF IT IS GOOD. IF THE COLD CONTROL IS O.K., THE START DEVICE ON THE COMPRESSOR MAY BE BAD. DOES THE COMPRESSOR HUM FOR A MINUTE AND THEN CLICK AND SHUT OFF. IT CAN BE EITHER THE START DEVICE (RELAY) OR THE COMPRESSOR IS BAD.
SOURCE: Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
SOURCE: Not all shelves freezing Alarm on
If this is not a frost free unit. I say replace it. I don't believe in recharging a deep freeze. You can never really trust them again. The food inside is worth more than the freezer. If this is a frost free unit, See if the fan inside is working. This can also be a defrost system proplem such as a timer and well worth fixing.
SOURCE: Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
SOURCE: Freezer keeps building up ice on the inside back
Good day!!!
It make easier for us to give the exact solution if you give the brand and model of your machine..
thank you very much for using fixya for technical assistance!!!
