This problem seems to happen with remanned toner cartridges. The link below provides the solution:
http://cincinnatiprinterrepair.com/service-call-of-the-week/50-hp-laserjet-m400-jams
SOURCE: HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
SOURCE: Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
SOURCE: paper jam inside HP Color Laserjet CM1312 MFP, not
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Go to HP Support at -> HP Support & Drivers 1
