Does it give any type of message as to why you can't continue? There is over 400 levels in the game, so you haven't maxed out. If there is no error message I would suggest contacting Facebook support and explain your problem to them.
This is usually a memory error. You may have too many apps open and need to close them.
Double click the home button to bring up all the open apps on your iPad. They will list in a line across the bottom of the screen. If you are on iOS7 or later you simply swipe the screen shot of the app upwards to close the app completely. Then go back to your home screen and open the app as you normally do. This should force the app to reboot and work as intended.
After closing all the apps you should then shut down the iPad completely. You can do this by holding the sleep button on the top edge for about 5 or more seconds. You will then see a slider on the touchscreen pop up that indicates you can shut down the device. After it is completely shut down, count to 10 and then press and hold the same sleep button on the top edge for 5 or more seconds to reboot the iPad. You can also plug it into your computer or charger at this point to force the iPad to turn on.
remove facebook app, turn off ipad. then turn back on and re download the app, when downloaded and installed dont go on facebook go into settings and facebook app then facebook settings and check the setting, also wile there check the video settings and turn off or on wifi only. this will save you memory load it stops the videos play automatically. if this does not sort out the problem then there is another app installed causing the problem.
Short answer. But Ithink you will find it usefull.
You should Google the Error code.
Just write: What is error -994 (FBAPIErrorDomain )
And then you'll find a site where Facebook helps you out.
It's much faster than me explaining it here:)
Good luck.
C.(DK).
You've locked rotation. In portrait (home button at bottom) position changed rotation lock switch at right edge (top switch). You'll see Locked/Unlocked icon on the screen.
Facebook has privacy settings that allow users to prevent comments or likes on their timeline. You've encountered one.
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
You can use This iPhone&iTunes Data recovery to Recover iPhone Contacts, Messages,Photos,Videos, Camera
Roll, Photo Stream, Photo Library, Message Attachments, Call History, Calendar,
Notes, Voice Memos, Reminders and Safari Bookmarks
