Question about Hoover AAA140 Front Load Washer
Hi. The Fabric Softner continues to be left in the tray on most washes. I have tried cleaning in and around the tray after taking it out and still the softner remains. Can you help?
4 Suggested Answers
6ya staff
SOURCE:
gittos73
peter gittos
  • 247 Answers
SOURCE: Hoover H120M Washing Machine No fabric softner and dial clicking round
always check your carbon brushes which are situated at your motor covered in a plastic covering must be at least 8ml long these start at 1inch in length may not be giving enough contact to your motor for the timer to click into action m8 but if these are ok then it will be more than likely your timer which is faulty with it not doing the water inlet valves properly
Posted on Aug 22, 2007
john_cross
  • 6277 Answers
SOURCE: hnf7167 not taking in fabric softner
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this doesn't cure i, the washer could have a fault with the water supply to the softener tray and would need a service call ;-0(
Good luck,
John C
Posted on Mar 13, 2011
michael_p_pi
Michael Pickering
  • 112 Answers
SOURCE: my washing machine (hoover VHF 710 front load) does not take up fabric softner from the compartment.
Could have something clogging the port. You're 110% sure you're following the directions EXACTLY as you're supposed to?
Reason I ask is because it can sometimes look as though it should go in one spot, only to read the instructions and find that it actually goes in another.
Posted on Sep 02, 2012
My bosch classixx 1200 expressnot taking fabric softner
Okay first try removing the soap try and cleaning it,secondly get a jug of water and partly fill the softner tray, at this point it should automaticly drain if not then looks like the Solonoid coil valve is at fault quite easy to replace cost of parts around £20......Good luck, hope the first part solves this......
Feb 02, 2011 | Bosch Washing Machines
Water collects in the fabric softner dispenser during in the washing and doesn't drain. We have to pour it out vbefroe washing the next load.
Take the dispenser out the washer and clean it very good.
Pull the caps off and make sure no fabric softner is hanging around the hole. The unit uses a siphon effect to drain the compartments.
It's normal to have some water left over tho. Just not full of water.
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine fabric softner problem
Remove the detergent compartment itself and clean it all up. Usually such problem is caused by blocked hole for softener. otherwise check coil continuity of the orange coloured water inlet valve
Update me about your progress
Jul 20, 2009 | Washing Machines
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Fabric softener not dispensing
Fabric softner trays often clog up, because a little soap powder in the tray by accident tends to block it. If you pull the soap tray out as far as it will go, you will see that there is a bit of the tray right at the back, probably on the left with an arrow or thumb print or indentation in it. If you press down on this it is a catch and it will allow you to remove the tray from the machine completely. Once out of the machine, the fabric softner cover will also lift out. Clean everything throroughly (Tak it outside and turn your garden hose full pressure on all the holes on the tray and then scrub it out with a toothbrush. Put the fabric softner tray mabc in and slide the soap tray back in the machine. This should have fixed it.
Mar 01, 2009 | Whirlpool Washing Machines
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Kenmore Eco Care Front load washer:Fabric softner clog
pull drawer out press down on tab rear left side and slide drawer out
Jun 04, 2008 | Kenmore 44832 Front Load Washer
Hoover AAA140 Front Load Washer Logo
22 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
