Hi Stacey Glasgow, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Hi Stacey Glasgow, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
The error displayed on Canon Printer number means sheet feeder needs to be replaced, it can be that gears in the printer and/or sensor have become broken or faulty. 5700 is a ASF cam error most likely which is called ASF cam sensor error.
remove the software from printer and reboot pc.install software back, but only plug the cables from printer when the software ask you for it. not before.
hi there
error 5700 is for your asf senser error clean or changing will fix this error.
error 5200 is for printer head temprature rissing high it may be by printer head or logic card.
Vista drivers for 5730 available here. Driver name indicates it is for the 5700 series, so this should work. Be sure and download and install the Tool Box (under Software) also.
I,m not 100% sure on this. But A 5700 error on canon printers.
Would mean that the paper sensor has failed, or is not working.
Hope this Helps.
Regards Mike@Compurepair.
