SOURCE: Kenmore 90 Series Electric Dryer will not run
Listen very closely to the dryer right as your pushing start.Is there any sound at all.Listen very closely because its critical on making the diagnosis.
SOURCE: Kenmore electric dryer series 90
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
SOURCE: My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
SOURCE: On the Kenmore series 90 electric dryer, where is
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
SOURCE: I HAVE A KENMORE 90 PLUS SERIES DRYER. IT DOES
check the door switch and also check the belt,if the belt breaks there is a switch inside that turns the dryer off
