SOURCE: which lead do i need
i just did this last night (compaq to 52" regza). you need a SVGA monitor cable male/male..(14.95 at ***-mart). plug her in and your good to go...
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
SOURCE: I have a Toshiba Regza 42A3030D TV but no manual.
Paid for only:
http://www.user-manuals.com/advanced_search_result.php?keywords=42A3030D+manual&forward=plist
Or try eBay.
SOURCE: how do you play games on a regza toshiba tv
What game system are being set to this tv?IF PS3 use a HDMI cable for connection to play.
SOURCE: No audio in a hdmi connection between a macbook
There is no audio because HDMI connection between Macbook and TV does not support sound. The HDMI you used does not have audio. In order words, you are not using the right/correct HDMI cord.
You need to connect with a single cable that carries both
audio and video like the Kanex iAdapt® HDMI V2 - Mini Display Port to
HDMI Adapter with Audio Support, or the Dr. Bott 9180-MDHK - Mini Display
Port to HDMI Adapter II, both of which are linked below.
http://www.cablematters.com/pc-56-26-mini-displayport-male-and-toslink-audiousb-male-to-hdmi-female-adapter.aspx
http://www.kanexlive.com/products/iAdapt51.html
http://www.drbott.com/press/100415.html
So endeavor to get any of the above cord and problem should be solved.
I hope the above makes sense to you.
Good luck.
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
Hope this helps, if so do rate the solution.
