Question about Sennheiser HDR 120 Consumer Headphones
Can I buy the headphones without the charger base?
My headphone does not work on one side and I want to replace it
3 Suggested Answers
Anonymous
SOURCE:
JL Thompson
  • 155 Answers
SOURCE: My sennheiser 120 headphones are wearing out. After much use.
You can buy the HDR 120 model which is basically the headphones lone
These will work with the base in conjunction with the set you have now.. or as a replacement
You can also buy replaceable ear cups for less than 20 dollars (check the Sennheiser website)
Finally you may want to replace the rechargeable batteries in the headphones you have
Just make sure you replace them with the exact type.. I believe those are NiMh AAA
Pop them out and go to any Battery Plus or Radio Shack.. a new set probably run you less than 7 bucks
My point.. for less than 30 dollars you can have your old headphones working and looking like new ones
Give the new batteries an overnight charge before using them
Good luck
Posted on Apr 30, 2009
Anonymous
SOURCE: Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Posted on Dec 17, 2009
Korg triton extreme synth. L/r outputs work fine by themselves put plug in both right side cuts out using headphone jack instead if you pull the right slightly out of input you get both sides working
I need more info to correctly troubleshoot this. However my best guess from what your telling me is that its either the Audio jack on the Korg or the headphones. If everything else is working properly replace the headphones and the Audio outputs. Post again with more details if that does not work
Jan 05, 2013 | Music
Left side of headphones not working
Hello if you think that you can do follow this link,you just need to do is to apply jumper.it is indicated in the image clearly Nokia 5800 Handsfree solution.Good luck
Jun 26, 2012 | Nokia 5800 XpressMusic Smartphone
Only the right side of my earphones work, how can i fix that?
either replace earphones or open up whatever you are connecting to and replace headphone jack
try headphones in another source to see if it is headphones or source where the problem is
or
try different headphones in same source also to see if it is source or headphones that are problem
Mar 25, 2011 | Skull Candy Audio Players & Recorders
My skullcandy agent headphones are only working on the left side,,,,,its blank on the left side
Sounds like there may be a problem with the cord.
Try plugging in your headphones and playing some music and moving the cord around. If the sound cuts in and out then you have a lose connection and will need to replace your headphones.
Mar 25, 2011 | Skull Candy Lowrider Headphones
Bose headphones only working on one side
You might want to look at my Tip on replacing plug/cable on headphones, it might solve your problem.
Apr 16, 2010 | Bose On-Ear Headphones
The Right side does not work.
i just bought the turtle beach x1's and had the same problem only it was the left side not the right and i was pushing the green audio connector cable to close together with the av componet connector and just slightly removed the audio cable from the av connector cable basically just slightly remove the headphones from the connection port on whatever you are connecting it to if that dosent work then most likely you have a lose connetion port on your device and will need to replace it or replace the device alltogether if the port can not be replaced.
Jan 30, 2010 | Skull Candy Lowrider Headphones
Sound Issues w/ PSP-1000
Your headphone jack is probably damaged and needs replacement. Here is one I found on the net: Repair your broken "Hands Free" socket, soldering required. This item is also available pre-mounted to the board, ready to plug in. Free shipping.
http://powergamingparts.com/psp-socket-and-housing--replacement.html
Nov 22, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Jul 05, 2007 | Bose QuietComfort 2 Consumer Headphones
Sennheiser HDR 120 Consumer Headphones Logo
77 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
