My starter is making a winding noise
If your starter is making a winding noise, it may be due to a few different issues. It could be an issue with the starter motor, such as worn out brushes or a shorted winding. It could also be an issue with the starter solenoid, such as a bad solenoid or a corroded electrical connection. If you are able to tap on the rear of the starter and make it start one more time, then it is likely an issue with the starter motor. If all is good and you need a boost, you may need to jumpstart your car.
