Question about Kyocera FS-1016 Printer
Kyocera 1116 code 6000 - Kyocera FS-1016 Printer
    New Friend:
  • 82 Answers
Check the lamp and the thermostat for continuity. Check the operation of the thermistor. If something defective replace. Most common is the thermostat. In addition, check the operation of the cooler fan on the machine's left. If it is not working then you have to fix or replace it. The most rare but existing failure is call service 6000 due to defective power supply. In this case the heat roller is stuck on press roller.
Posted on Jun 11, 2014
2 Suggested Answers
6ya staff
SOURCE:
Evildice
Vasil Hristov
  • 222 Answers
SOURCE: Error code 6000:0106504
Fuser problem, you shall change fures termistor or lamp or both..Good Luck
Posted on Aug 14, 2009
What does this error code mean 6000:0185578
Error code 6000 is usually a Fuser unit error. You need to replace the fuser Unit.
Aug 19, 2014 | Kyocera FS2000DN Laser Printer
I have a kyocera FS-2000D and an error 6000:0087166 what can I do...???
Error Code 6000 is fuser code, you need to replace the fuser unit, make sure there is no paper stucking there first!
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Nov 10, 2011 | Kyocera FS-2000D Laser Printer
My Kyocera FS-1116 MFP says 'printer error'/'engine panic'.
If you get the Engine Panic error message, you need to turn the power switch off and then back on again. If that doesn't fix the error, contact a service representative to help resolve the problem.
Oct 17, 2011 | Kyocera FS-1016 Printer
Kyocera fs4000dn error code 6000:00064
6000 error is a fuser error. Check connections; make sure the back door/cover where the fuser is located is closed. Turn the machine off, unplug, plug back in, and turn printer back in; if you are still getting the error the fuser will need to be replaced.
Jun 08, 2011 | Kyocera FS-4000DN Laser Printer
Hi, I have an ecosys fs 2000d, with a call service message 6000:0026965, somebody help me please
Call service message 6000 in Kyocera is a fuser error code. The fuser must have gone bad.
Regards,
Shrey
May 31, 2011 | Kyocera FS-2000D Laser Printer
I need drivers to install Kyocera FS-1116 MPF multi scan as I have lost the CD
Kyocera FS-1116 MPF Drivers
Visit the above link and download the required drivers for the Operating system you have on your PC
Installation Manual may also be referred.
Hope it helps! Good Luck!
CreativeTECH
Apr 15, 2011 | Computers & Internet
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB
- Defective the engine/high voltage PWB.
Dec 15, 2010 | Kyocera FS-1016 Printer
This seems to be a fuser error. You need to take it to your local sevice agent for repairs.
Aug 13, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS3900DN Error code Call Service6000:0057457
6000 is the error code 0057457 is the page count
6000 means the fuser is faulty, you're going to have to replace it
Jun 16, 2008 | Kyocera Office Equipment & Supplies
Kyocera FS-1016 Printer Logo
118 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
