SOURCE: changing blade drive assembly on
Ok the silver metal plate goes on first then the black latch will connect to the hinge, there are two small holes either side of the latch where two spring ends poke through then simply screw it back on, not sure if you can put the blade drive on the wrong way.
If your still having trouble give us a call and we can talk you through it www.angliaclipperservices.com
