To mute or unmute a call on your Motorola H710 Tap both the volume buttons until you hear a mute tone.This will mute or unmute the headset during the call.
Hope you're satisfied with my solution.Thanks for choosing Fixya.
The volume keys are the silver keys on the top and bottom. Simply push the volume up button to adjust the volume If you are not sure which button is volume up, or simply want to change which is which, you can change the button orientation. Here's how:
-Close the boom to turn the headset off.
-Press and hold down the desired "volume up" button and open the boom. Keep the button pressed until the indicator light flashes blue three times.
If you just want to see the user's manual it's here...MANUAL
Make sure your phone is in discover as well. Also make sure your holding down all 3 buttons at the same time for at least 10 sec. then it should go into discovery.it will blink then go solid.
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
try and remove the current bluetooth device. Close the headset. Go to thephone and choose discover, or search. Open the headsetand press and hold the big button. It should then turn purple and should be recognized.
Also make sure the batteryon theheadset is charged before doing this.
There is also an online video manual for H710 Motorola headset on www.HandBookLive.com under Electronics. There are chapters on pairing as well as buttons operations, and there is a link to the manual, as well as a quick reference sheet you can open from the Quick Start video chapter, and print it.
