Have read thru the manual and see a something for the volume but that did not correct the problem. Treadmill has very time on it
SOURCE: The Incline is stuck at an angle
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
SOURCE: How do you put the treadmill down?
There is a knob on the support bar behind the treadbelt deck. Give the deck a little push up, then pull the knob out and lower it.
SOURCE: where can I get a manual for my epic treadmill
Go to this link.
http://www.iconservice.com/CustomerService/manuals.do
Find your model number. (located on the lower frame under the walk belt in th front)
Input the number and download it for free.
Thanks Tim
SOURCE: We have an Epic 550
Just got off the phone with Icon. Here's the Fix:
1) With the remote control that came with the Treadmill press "Menu".
2) Then enter "1591" quickly with the number buttons.
3) Use CH or CH - to choose flip orientation.
4) Press VOL or VOL - to select
5) Press Exit
That should do the trick!
Testimonial: "THANK YOU THANK YOU THANK YOU!"
