SOURCE: how do I remove the toner cartridge FROM MY
Download the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002698/cv_hl2240d_usaeng_usr_0b_b.pdf
It's described in Chapter 4, Routine Maintenance->replacing consumable items->toner cartridge
Replacing the toner cartridge, page 97
SOURCE: Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
SOURCE: brother hl-2240 toner light wont go off after
Hi Rick,
Click on the link's below to follow the instructions
Solution 1
Solution 2
I had this issue and I used a small (.5 x .5 in.) piece of black electrical tape to cover the
sensor hole on the non-gear side of the cartridge. By covering the hole
the printer is fooled into thinking the hopper is full of toner.
Regards,
Suhail
