SOURCE: frigidaire not dumping the ice
Hi: Dumping the ice is the start of the ice making timer. Before you replace the ice maker... Set the freezer one setting colder. The ice maker wont make ice if the freezer is not at zero degrees F. Just because things are frozen in it dosn't mean it is at zero. This happens a lot in the summertime. After resetting the temp don't open the door every hour to see if it makes ice as you will just dump the cold air out. Listen for the ice to dump, give it 24hrs. I hope this helps, Jeff
SOURCE: i have a frigidaire side by side refrig. mod FRS26RLECSE
HELLO,
This fridge may be lacking the chemical called freon, a typical coolant agent used in refrigirators, try to replace the coolant, and then let the fridge run some time. It should be back on cooling as normal...:)
SOURCE: My frostfree Frigidaire refrigerator is making a
if the knocking is coming from the compresser than there is nothing you can do to stop it.
SOURCE: The ice maker is making a knocking noise, even
fridge is making a knocking noise like someone tapping on a pipe
SOURCE: 18 ft frigidaire 5 years old used seasonally fan
thata a close call, if you indeed know that the compressor is running.. should be hot when on..and still no cool in freezer section. sounds like a MAJOR refrigeration issue, requiring sealed system repair.. its close because the manufacturer covers selaed system repairs for 5 yrs. ck your manual and with the manufacture first, because you can replace the unit for cheaper than doing repair out of warrantee,
I appreciate your post, friend!
Based off what you have described your Frigidaire refrigerator's icemaker is making knocking noise. This could be due to your water valve or motor. Since it is difficult to pinpoint the cause of the knocking noise I would suggest having a professional technician out to perform an accurate diagnosis. This will help you avoid any unnecessary part purchases. Good luck. -Matt
