You can find the manual for Toshiba Satellite A45 on the link mentioned below:
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su587690/satellite_a40_ug_20031113.pdf
GuruAid.com
SOURCE: dvd writer for toshiba satellite doesn work
SOURCE: INSTALLATION OF DVD ROM DRIVE FOR TOSHIBA SATELLITE A45-S150
Underneath your satellite there should be either a spring loaded lock to unlock/release the drive, or there could be a panel to remove that will expose a single screw that holds your optical drive in place. Releasing the drive with whichever locking mechanism is securing it should allow you to remove and install the new drive (if it's a screw, don't forget to replace it after the new drive is installed).
I hope this helps, and Good Luck.
SOURCE: location of memory in Toshiba satellite A45
CLICK HERE for a step by step.
Basically you have to...
Remove this trim piece just under the lcd
Then remove the keyboard...
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: toshiba satellite a45-s250 bios password removal
try this man:
first: download hiren's boot cd
Second: burn it using nero
third: boot it at hiren's boot cd
fourth: after booting from the hirens bootcd choose bios/cmos
fifth: use bios!
sixth: browse for any passwaord there, but do not use the blaster, it can cause system failure, i think the admin password for a45-s250 is ami..
hope this helps you
