Question about Garmin GPSMAP 60CSx GPS Receiver
Garmin 60csx: A spot burned in the LCD screen
A spot burned in the LCD screen and batteries keep emptying themselves, when the unit is turned off.
http://www.nwogeo.org/Forums/viewtopic/t=564/start=45/postdays=0/postorder=asc/highlight=.html
Others have reported that inserting the batteries backwards can cause this problem also!
http://www.fixya.com/support/t338492-broken_screen
Hi nick160460! Do you have these 60csx LCD for £20 + p&p or does someone know if these are available somewhere?
  • Michael Grimes
    Michael Grimes Apr 08, 2017
    Hi Eilifur Bjornsson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Eil?fur Bj?rnsson Apr 08, 2017
    Solved!
Anonymous
SOURCE:
Anonymous
  • 113 Answers
SOURCE: Garmin GPS 45
It is probably one of the following:
1)Old Software
In 1999 the GPS satellites were reset and the new almanac data had to be loaded into the GPS 45 for it to continue to work. It was not uncommon for that model to quicly kill a set of batteries when it is having difficulty acquiring, which would cause it to shut down in order to save the batteries for its internal memory.
I just did a quick search of the Garmin website and it appears they no longer support that model. If you go to their support page and send a request for a software update they can probably e mail it to you. The update is free but to down load it, you need a PC interface cable (RS232 serial port connector) Part Number: 010-10141-00 Suggested Retail Price: $ 38.09.
2)Bad antenna
To rule this one out, borrow an antenna from another Garmin 45 or Garmin 48, or plug the unit into an external antenna and see if the unit still shuts down. The drawback to this method is that you can buy a new GPS that is superior to the one you have for about the same price as an external antenna.
3)Bad batteries
If your batteries are low, the unit will automatically shut off to protect its internal memory. I tried a lot of different batteries in my 45 and I found that Eveready alkaline batteries worked best. Rechargeable nicad batteries don't work very well because they fool the battery meter. Newer models have a setting to specify that you are using rechargeable batteries.
Ultimately the best advice I can give you is buy a new GPS. For less than $150 you can buy a new model that is more accurate, more reliable, stores more waypoints, has a better display, is easier to use, and gives you more valuable information.
Please rate this information as helpful.
Posted on Jan 24, 2008
Anonymous
SOURCE: Garmin 60csx turning off while in use
OK, I've managed to overcome the problem :D I've formated the micro SD card and now it works without any glitches :D
Posted on Jul 22, 2008
Anonymous
SOURCE: Garmin 660 LCD broken
Are you sure the LCD is broken? or the touchscreen?
Posted on Sep 22, 2008
Anonymous
  • 9 Answers
SOURCE: Garmin Forerunner battery replacement
I used the battery from a sumsung hue cell phone.
http://www.jimandkatrin.com/codeblog/2009/08/forerunner-305-battery-replacement.html
Posted on Aug 15, 2009
pfbsouza
  • 10 Answers
SOURCE: Garmin 60CSx screen just fades off and it shuts down
Try to load latest firmware on the unit
Posted on Aug 21, 2009
My garmin 60csx started to smell like electric burn. It then showed a burned spot on the screen. IF the backlit light is off then the burn doesn't show but if it is on, then it shows a burned spot in
Should it not be 12volts? If its really 250 volts i garmin shouldnt switch on anymore. And actualy use android and google maps in it. Garmin is useless anyway
Feb 25, 2018 | Garmin GPSMAP 60CSx
Electrical burn Garmin Rino
Send it to Garmin with a letter detailing what you did and ask for an estimate of repair.
May 14, 2010 | Garmin GPSMAP 60CSx
I would suggest sending it to Garmin for an estimate of repair. We have no way of knowing the damage that has been done.
Mar 23, 2010 | Garmin GPSMAP 60CSx
I have a Garmin 60csx that won't power up
On my GPSmap 60CSx the screen fades away after powering on - just like the battery is empty. Changed battery and used USB power. Always the same. When removing  the 2GB micro SD memory card then it comes up. Replaced the memory card and now it powers up fine. Seems that the memory card is damaged or causes a short circuit.
Apr 26, 2008 | Garmin GPSMAP 60CS GPS Receiver
Apr 15, 2008 | Garmin GPSMAP 60CS GPS Receiver
Broken screen
if you post your e-mail add we can take this further as I may have a lcd screen that you can have for £20 + p&p
regards
Jan 06, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin gps
Try this link to Garmins driver downloads: http://www8.garmin.com/support/download_details.jsp?id=591
USB Drivers software version 2.2.1
Nov 14, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin gpsmap 60csx won't acquire satellites
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Sep 17, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin GPSMAP 60CSx GPS Receiver Logo
141 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
