My Logik handset is locked and unlocked by holding the single side-button until it beeps, then holding the * key (with "key" symbol) until the lock icon appears/vanishes on the screen.
Most likely have locked it. Press and hold the lock key lower left button. it will beep several time when unlocked the lock symbol if in the upper left side of the LCD screen next to BANK
When you reintilize the scanner, it should lose all programming and settings. Hold down the Tune/Clear button while pushing the reset button. Do not release the Tune/Clear button until the display clears and returns.
Dude just remove your side key away from your phone u vl find a small up & down key in side slot of side key take your stick & put it down to unlock use ur stick to lock or unlock ur phone..
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
