Vehicle Parts & Accessories Logo
A
Anonymous Posted on Jun 05, 2014
Ac not blowing through center vents - Vehicle Parts & Accessories
Jensen Beach Speed Shop
Level 3:
Master:
  • Master 710 Answers
  • Posted on Sep 07, 2014
Master
Level 3:
Master:
Answers
710
Questions
Helped
141112
Points
7635
Check for a bad control unit or bad actuator door/solenoid/motor.
3helpful
2answers
I have a 98 Buick Lesabre Limited. It blows Cool air, but not Cold.And also, I can't seem to make it blow out of the Center Dash Vents.
Cornelius, vent problem could be a pinched or loose vacuum line on controller,faulty AC vacuum motor, faulty AC programmer,etc. needs to be checked out by a good Tech, diagnosed and estimate on repair.
As far as vehicle only blowing cool air, issue could be blend door issue, plugged AC condenser core dirt/debris, low AC refrigerant, plugged AC lines internal, failing compressor, etc., again should be checked out, diagnosed and estimate for repair by a good Tech.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1998 Buick Lesabre No Air From Dash Vents
http://repairpal.com/ac-vent-problem-346
Car AC Not Blowing Cold Enough Car Repair Information From MasterTechMark
My Car Is Not Cold What Could be Wrong Elite Auto Repair
2answers
Air does not blow from the center dash vents
My ac is only blowing on the defrost but none on the center dash vents. How do I clean the ac hoses? It may be blocked.
1helpful
Ac will not blow through center dash vents. Ac is working but blows through defrost. How do I reconnect or fix the vents so the ac blows through where it is supposed to? the side vents are functioning...
Bring the vehicle to a repair shop. This could be a dash board nightmare and you have to discon the SRS system before working on the vehicle.
Or its the position switch or its actuators. It a little tricky to remove the switch to see what happens once you do that and jump the terminals. The relay is pretty easy to check out with a voltmeter. Its your call the actuators are a pain to get to.
3helpful
Heat blows out driver vent when ac on
this problem is caused by a defective air temperature control blend door actuator motor, it is about center of dadsh in air ducting, it moves the door that diverts air for cold from ac or hot from heater, you must remove the dash to repace it, about a 15 hour job fotr a home mechanic with a factory repair manual, nearly imposs without one.
Air Conditioning blowing cold out of all but 3 front vents
Vacuum line has to be connected to this system in order for it to work properly.
3answers
Center vents cold side vents hot please help bthibs
hello,good day,seems your recirculating pump need tobe check,ty
1helpful
2answers
98 LeSabre AC vent
it sounds like a vacuume motor that is out or going out also check all vacuume lines for cracks
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
