Blueair 403 HEPASilent Air Purifier, 365 Sq. ft. Room Size, 30-70W, 4 Speeds 75-240CFM, 27-51 dB Noise Levels, 240 CADR Clean Air Density Rate, 33Lb Logo
A
Anonymous Posted on Jun 06, 2014
Blueair 400 doesn't go off speed 3 - Blueair 403 HEPASilent Air Purifier, 365 Sq. ft. Room Size, 30-70W, 4 Speeds 75-240CFM, 27-51 dB Noise Levels, 240 CADR Clean Air Density Rate, 33Lb
My Blue air purifier won't turn on?
Question edited for clarity.
Question moved from Computers and Internet.
Make sure the filters are properly seated. Contact them at Support direct. It sounds like it might need dealer repair.
https://www.blueair.com/ca/customer-support.html
2answers
What size is the fuse on the Blueair purifier.
Hi there.
15 amp. Also remember there is a reason why the fuse is not working. Goodluck ..
2helpful
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Blueair 301 Air Purifier Owners Manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Blueair model by clicking the link below.
http://homeappliance.manualsonline.com/manuals/mfg/blueair/301.html
You can purchase a wide variety of high quality Blueair replacement parts for your Blueair Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Blueair
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
2helpful
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
2answers
My blueair 501 suddenly stopped working. I turned it off to move it to another room, and it will not come back on. Outlet has power. Is there an internal fuse I can replace?
The power cord had burned out right at the point where it connects to the female receptable (the end that connects to the unit). Need replacement cord.
83helpful
RED CHANGE FILTER LIGHT DOESN'T GO OUT AFTER CHANGING FILTER
I had the same issue.  Press and hold the 'TIMER' button untill you hear a beep and it will reset.
Dead
check power outlet / test the Blue air power cable w/tester continuity , switch on and off, tester move forward and reverse meter means good plug/ if does not move the fuse of the unit is open.need to replace.
Top Blueair Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Blueair Air Purifier Expert? Answer questions, earn points and help others
