SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
SOURCE: Sony KDL-52XBR9 power/standby LED blinking. TV
This is either your LCD backlight, inverter/power board or both. Neither of which are serviceable by the consumer, unless a visual inspection of the power board shows swollen or ruptured capacitors. This you can do yourself and is the most likely problem. Just read the side of the capacitor and go to radio shack, or online to find the right replacement capacitor. When re soldering be sure your negative and positive leads are in the correct holes.
SOURCE: sony kdl-40s2000 won't stay on and blink red 4 times
That error says backlight failure. It has to be troubleshooted to find out why.
SOURCE: My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
SOURCE: sony kdl-40w3000 does not turn on. Standby light
sony kdl-40w3000 does not turn on. Standby light keep blinking. What is the problem
