That's not a lot to go on. What computer OS are you using? How did it get deleted in the first place? Any new programs uploaded recently? Have you checked for viruses/malware?
The automatic reappear printer problem its come when you are connect to two and three computer in same network, when the network on the automatic search the printer in network if you install that printer in any other PC so automatic the printer is add in your printer list.
For installing the printer not nee to delete the all printer, put the installation CD in Rom and click the setup.exe
And before that you have to run the Clear utility sofware from Kodak, this is to remove the previous install on your PC
Clear utility is located at this site
hi, HP Officejet 5610 All-In-One InkJet Printerhas few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Try uninstalling and reinstalling your printer. Go to Printers and Faxes, right-click on your printer icon, then left-click Delete, then left-click Yes. Then on the same page click File > Server Properties > Drivers > Delete. If it won't delete, re-start your computer and try again. When you have done all this, reinstall your printer, using the manufacturer's CD.
This is a common problem with Windows. You don't need to delete the printer or re-install anything. If a job gets stuck at 'deleting, just reboot and when the PC comes back up the job will not be in the queue any more.
I had a problem with mine also. It kept giving me an unsupported cartridge error. I finally took it back to the store and exchanged it. The replacement works fine.
ok
frist of all remove u have insatll all printer from the add remove progerams & then delet all your 12 printer installed
then after reinstall your printer driver for vista & try to print
Hello, you will need to complete the add new hardware wizard, sometimes the drivers are corrupted and the wizard ends before all installation takes place (undertaker02 this is also for you) Do this:-Log on to your computer by using an administrator account. 2. Click Start, and then click Run. 3. In the Open box, type regedit, and then click OK. 4. Locate and click the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\LPTENUM 5. Right-click the registry key, and then click Delete. 6. Under Confirm Key Delete, click Yes. 7. Close Registry Editor, and then restart your computer. When Windows XP restarts, it will detect the printer and install support for it. After the printer is installed, it will no longer be detected each time you start Windows XP.
