Kyocera Mita KM-5035 Printer Logo
Isaac Posted on Jun 06, 2014
Replacing a DC controller board
How to fix or replace a DC controller board
Joseph Koata
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Aug 28, 2014
Joseph Koata
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
55504
Points
34
When replacing DC/main PWB or engine board, be sure to remove the EEPROM from DC, main PWB or engine board that has been removed and then re-attach it to the new DC/main PWB or Engine PWB, cheers
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
1helpful
3answers
How to replace DC controller board
HP Service Manual Library
Download the manual here, this is your best option and will show you step by step.
1helpful
3answers
Brew Drive Motor 33V DC with 7V DC.
Sorry but this device is specially made to be , so called , NOT FIXED!
You can still contact the shop/store where you bought the product and ask for a repair.
My customer explains that water got poured into her HP LaserJet 4200, now it won't power on, no display, no engine noise, nothing. I have replaced the large power supply on bottom, and the fuser,...
I have had this problem before and replacing the high voltage board ( that is the large board situated under the printer ) fixed it. However if you have replaced this board then I would agree that the water also took out the DC Controller Board.
The fuser probably did not need to be replaced.
2helpful
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
1helpful
2answers
Canon ir 2016j
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
15helpful
2answers
Error code 59.c0 in HPLaserjet 5550
This means a printer motor error has occured. From the service manual: C developing disengaging motor rotation error.
To fix:
Developing disengaging motor
error
1 Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2 Replace the developing disengaging drive assembly.
3 Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
So, at the very least you'll need the developing disengaging drive assembly and, if that doesn't fix it, then you'll need the DC controller board. My bet is the DC controller has failed.
Sorry for the bad news, but please rate this solution as fixya even if it wasn't what you wanted to hear. Thanks.
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
1helpful
2answers
Canon copy machine NP6025. Error E800.
According to what I have E800 is eith a problem with the Mains switch or DC controller. I doubt it's the switch but there are many things that would cause a DC controller error. You might try Hytec Board Repair for help on the DC controller. http://www.hytecrepair.com/
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
