Amana fridge, fridge works great, freezer runs is cold but won't freeze
SOURCE: amana fridge with freezer on bottom
Check to see if there is any frost buildup in
the back wall of the freezer. If so, it is not defrosting as it should.
If
you don’t know what these are then unplug the machine and let the ice melt in
the freezer overnight with the door open. Then try it the next day, if is
cooling fine then you need to have a service person replace one of the above
items. If it still has a problem then it might be the compressor and you should
probably replace the machine.
SOURCE: amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
SOURCE: Amana BR18 fridge/freezer. Fridge is cool but not
you maybe blocking the circalation in the freezer the way you have things packed in there. Move large items away from where the cold air blows in.
SOURCE: Amana upright deep freeze model AFU1505BW K3: We
Please check your compressor and capacitor for malfunction. Check also the current draw and compare to your manual. If you got lower ( very low ) current draw reading , you problem with compressor. It may run out of refrigerant and need to top up.Also check your thermostat setting adjust to medium or a little bit colder.
