Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
How do I check the compressor "?" - Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that you want to know how to check the compressor on your Frigidaire refrigerator. I will be more than happy to assist you. In order to better assist, I kindly ask for the model number of your appliance. Typically, this number will be located inside the refrigerator area on the right or left wall. Looking forward to hearing from you.
-WP-
Posted on Jun 12, 2014
Anonymous
SOURCE:
U-Line ice maker compressor won't run
Dose compressor fell too hot ? There could be several things wrong. First you will need to get out your Volt meter to make all test. With unit calling for freeze cycle the condenser fan and compressor should be running. Check at the compressor to make sure your getting power to the over load switch and then through it to compressor. if not then check to see if compressor is to hot and has the switch open> If so then unplug unit to let compressor cool down so switch will close. when switch closes plug unit back up and start up unit check to see it compressor starts if so then you will need to see what is causing compressor to over heat. could be dirty condenser, low charge, fan dropping out, Bad compressor.
Mar 07, 2014 | U-Line Icemaker
Compressor not coming on check red wire on compressor with test light compressor comes on pressure good high and low air cold
If the compressor came on when you were testing it with a test light, it sounds like something is wrong with your ground for your compressor, and completely the circuit through your test light.
Jul 01, 2011 | 2003 Honda Civic
GOLDAIR 3 MODEL RAS-90(3) SHOWS ERROR F6 WHEN SWITCHED ON?
F-6 means for high current of compressor.Check to earth 50 MOhm minimum, if any reading. compressor is grounded. check run current, if it's high current, compressor defective.
Check compressor windings all equal 1 to 4 Ohms.If not replace compressor.
Please re confirm with all wiring (may be loose connection, short of wiring) before replacing compressor.
Helpful?
Jan 19, 2011 | Heating & Cooling
I have 2 a/c compressor in our bluebird bus 2008,one of the compressor dont wanna engage.I replace the 3 relay the a/c switch,circuit braker and still the same,,,,,pls. help!
First check your compressor.Power off; Remove wiring from compressor terminals. Now check by ohms meter with all three terminals. A,B,C . Check A&B, A&C and B&C . For 3 phase compressor all will be equal. if single phase compressor there will be C,S,R. Now check with C&S, C&R and S&R. S& R will show the total other two. It means your compressor winding is o.k.
If compressor is o.k. check wiring.Helpful?
Jan 09, 2011 | Heating & Cooling
It is not cold. The fan works but when the cold air should come on it doesnt. You can hear it trying to kick on for a moment but it doesnt, it just keeps blowing as a fan. Thanks for any help. I would even...
If compressor is not shorted out to the ground and between each leg of compressor multimeter reads resistance You could try to install 3 N 1 hard start kit. But most likely compressor is weak, be prepared to replace compressor soon. Here is my situation on this compressor - everything was running, but compressor. I check for short and resistance on windings - everything shows that its a good compressor. Installed Supco 3n1 kit. Unfortunately it did not help - need a new compressor.
May 01, 2010 | Frigidaire FAS185M2A Air Conditioner
The a/c keeps cutting off before the room gets cold. The fan stays on but now cold air.
check the timer settings on the control. they may be set to something you may not wish to be set..
Aug 29, 2009 | Heating & Cooling
Please help our ac compressor wont come on
Hi, did you change, capacitor for compressor too. check compressor overload switch,(relay) normally located on compressor terminals, (where you connect wires to compressor) that's the device that goes klix when compressor goes to start, could be faulty, or maybe low voltage from your mains(house panel) check line voltage, with digital volt meter, some compressor won't start if voltage drops to low, yes fan will work, could also be, your compressor has a lock rotor, (hard start), you can buy a compressor hard start kit, from appliance store, and try to start compressor, or maybe compressor internal winding, are damage, especially now in summer, when you got a lots of voltage drops, check compressor winding, check compressor winding for short circuit, remove cover on compressor, remove 3 wires from compressor terminal, use ohm meter, put one tester lead on copper tubing that's connected to compressor, and next lead to compressor terminal, one by one, if you get beep (continuity) from anyone of those compressor terminal, you got a short- circuit in compressor, you will have to replace compressor, but if there's no short, them try hard- start kit, replace overload relay, you will see it at compressor terminal location, after you remove cover. good luck.
Aug 10, 2009 | Heating & Cooling
Ac blow hot air.has been recharged
First you need to check if the compressor is actually kicking in when started and you can do that by looking at it and you will see if it is working or not. If not working you ned to check the folowing : 1- AC compressor is getting electric , if not check the relay for the AS compressor. 2- Check if the AC compressor's clutch is kicking in (that is the part that is located on the front of the compressor , where the belt is fitted) 3- Check the compression of the AC compressor via a proffessional.
Jul 18, 2009 | 2000 Jaguar S-Type
Dead Compressor
take cover off compressor electrics and check start device ok and not burnt out. if compressor is warm to touch, indicates faulty compressor. take all electrics off compressor and check for continuity thro windings.
also check for power to compressor - if no power, indicates fault in board
Nov 04, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
May 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
