Everything else works ok..Call goes directly to voicemail
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
1. Find "Keypad"
2. Choose option
2a - Divert all calls
2b - Divert missed calls
2c - Divert if unavailable
2d - Divert if busy
3. Return to the home screen
SOURCE: Hello, My I phone 3G
I have and iphone 3g and my applications are not working, as soon as I tap on them they open for 2 seconds and they close down, the only ones that work are the ones that came with the phone.
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
SOURCE: Phone only rings a couple of times then goes to
Go to call settings. Choose call divert. Select do not divert calls. Press OK
SOURCE: RingerTone not working.Cannot hear incoming
check your phone settings .Or it was already on your ringer tone have problem the speaker not working. .
Have you selected a ring tone for incoming calls? Do you have the phone set to send all calls to voice mail?
