SOURCE: I need the puk code
puk code is provided by your service provider itself, call your service provider means the one who provides you the mobile phone connection.
the following details are essential for the same
1) which mobile phone number the sim was carrying which was last put in your mobile phone , which caused the puk code.
2) security details of the person on whose name the sim card is issued , like the name, address, birth date etc
3) mostly if u have been provided with a MIN number at the start when taking your mobile phone services, you could navigate through their IVRS to the spcific slot and put down your mobile number and the puk unlock code will be provided to you.
4) Call up the help line number of your respective service provider and they should help you out as the PUK code is service provider specific.nothing to do with the manufacturer of the mobile phone, but it is specific to the SIM card.
SOURCE: puk code for nokia 6230 orange
what do you do if you cannot contact orange customer service because your phone is blocked?
SOURCE: puk code nokia 6230
thank you for choosing Fixya.com.
it seems that your simcard are looking for PUK number.
PUK means Pin Unblocking Code..1234 is the default code for your SIm or u have to contact service provider to getting PUK..
another option if you remember the time when you buy your sim card it has a small envelope
please check if you still have it.
look for a small piece of paper it contains the PUk numbers such as PUK 1 and PUK 2.
but if you already lost it we do not have any other chance just to buy a new simcard.
PUK are only related to a simcard of your mobile.
the worst problem if you input 3x or 4x of wrong number # of PUK your sim will be permanently block so if you encode 2x already don't try again untill you did not find the PUK number or you will going to change a new sim and all your files save in simcard will be lost be carefull.
Please don’t fotget to rate our answer’s properly.
SOURCE: PuK code
PUK codes are available only from your Carrier like t-mobile or AT&T. you need to contact them and they will easily provide you with one. Entering too many wrong codes will burn out your sim card. So don't try too many wrong codes.
SOURCE: Puk code for nokia 6230
Inorder tosolve your PUK problem, *kindly contact your service provider (customer care) *Tell your phone number and they will give your PUK code *Enter that code on your cell phone(Wall that ask puk code) *Then your phone ask another pin code&to verify,there you can type your desired code(say 0000,00000,1234,12345). * Then your phone will restart normally.... "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
