Even on the permanent press cycle the clothes are coming out very wrinkled.
SOURCE: Maytag electric dryer model # MDE2500AYW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: Maytag Dryer wrinkles my clothes.
I only know of one or two things that might help.
One make sure there is not too many clothes in the dryer.
Two, if you have a setting for permanet press use this.
Good luck.
SOURCE: Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
SOURCE: Maytag MDE3500ayw having problem in
If the drum is overloaded, the clothing can be wrinkled, due to improper tumbling. This will also prevent the clothing from washing and rinsing properly, which causes wrinkling as well. When moving clothing to the dryer, shake them well to help reduce wrinkles.
NOTE: For combo model washers, when washing a large single item like a sheet, it is recommeded to remove and reload that item before the dry cycle begins.
Check that the inlet hoses were not accidentally reversed during installation. If the hoses were, turn off the water valves and reconnect the inlet hoses correctly. If the hoses are reversed, the rinse temperature will be hot and set the wrinkles in the clothes. It can happen!
Do not let clothing rest too long before removing them to dry. Some wrinkles are caused due to high spin speeds as the items are forced against the drum. However, allowing the clothes to sit in machine for extended periods after cycle is complete causes wrinkles to set in. Shake clothing well after removal from unit.
Also If too much softener is used, it will leave residue in the clothing that will weigh them down and cause wrinkles. Dilute thick fabric softener 50:50 with water so that it dispenses properly.
SOURCE: I can't seem to get my clothes to come out of the
Hello, cp I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
