Testimonial: "Sorry, I think I mislead you. I am working on a dryer"
SOURCE: Is there a reset switch on the dryer. My dryer
Sounds like the filter. Unscrew the top, slide lid back and use a voltage meter to check the voltage of the dryer when it is plugged in. Check the voltage where the wires come into the machine, before the filter and after it. Work along the wires to the board. If you get voltage up to the board, you need a replacement board from the manufacturers or get a new dryer - depending on the model you've got it might be cheaper.
SOURCE: Dryer is not starting when i push the start
Check lid switch. When you open the door there is a lever that hangs down so the door makes contact.
