Question about Samsung Televison & Video
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
Black line down the centre of screen
  • Samsung Master
  • 933 Answers
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Posted on Jun 11, 2014
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Sky PDS4250 42'' Plasma TV - Black line down centre of screen
not sure if this is the fix or not ...but i was tryin to fix a problem with my tv(not the same as yours)...but in the menu under adanced you can split the screen ....when i do that it puts a blue line down the middle of the screen
Posted on Dec 04, 2008
Anonymous
  • 289 Answers
SOURCE: ORANGE OR RED VERTICLE LINE DOWN RIGHT SIDE OF SCREEN?
hi..the probelm is due to the video circuit board.
only when you have a problem with the video
circuit board you will get such type of faults.so
you have to check the video board immediately.
check it out..
thank u..
rate me..
Posted on Feb 28, 2009
Anonymous
  • 80 Answers
SOURCE: Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Posted on Jun 01, 2009
Anonymous
SOURCE: There is a big black verticle line on the screen
vertical lines in general are caused by the data boards (buttom of screen) theres a left one and right one these boards are atached by ribbon cables going to the logic board .first all ribbon cables must be checked and reconnected to make sure there well seated ,also pass compressed air ( can ) , if this dose not solve problem try slightlypressing on the connecters replace defective board , on many lg tvs the connecter on the logic board is defective slightly pressing solves problem ,if this does not work you have two choices the data board thats on the same side of the line is defective you may try to clean the brown flex connecters that plug to the data board these connecters are not easy to reconnect be delicat and patient !!!if data board does not solve replace logic board !
Posted on Jun 10, 2010
Display with black Spot in center and irregular lines Up & Down
Your display is damaged from pressure. Something put enough pressure on the center of your screen that it touched the LCD.
Aug 03, 2015 | Nokia 6300 Cellular Phone
Relisys tv model no rp4207b ru black line down centre
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 25, 2015 | Relisys Televison & Video
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
E
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 28, 2009 | Televison & Video
please click here and follow the instructions to resolve the issue.
May 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Diagonal black line appearing in the pic bottom 1/3 of screen when this does not appear white burnt out line appears in centre of screen all this appears in the pics on the memory card mostly the black...
Try formatting the memory card in the computer then format it again in the camera and see if that clears the problem. Also try another memory card but if the problem persists it probably needs a repair.
Nov 02, 2017 | Canon Cameras
Olevia 242-T11
Screen went black unpluged won't even turn on.
Dec 27, 2008 | Olevia LT42HVi 42 in. LCD Television
Dec 04, 2008 | Protron PLTV-4250 42 in. LCD Television
Funny screen and refusal to start
Sounds like a Video ram or system ram problem which is on the system board. Needs service.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 22, 2008 | Toshiba Satellite A105 Notebook
Televison & Video Logo
224 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
