You have a defrost, or air circulation problem. If there is ice on the inside of the freezer walls it is probably a defrost problem, provided the freezer fan motor is running. If it isn't running the fan motor is the problem. If the motor is running it is a defrost problem. Three things can cause a defrost problem, the defrost heater is bad, the defrost terminator is bad, or the defrost timer is bad. On the newer refrigerators the defrost is controlled by a control circuit board. If it is bad it can be expensive. If you have an older refrigerator, I recommend replacing the defrost timer, the defrost heater and defrost terminator. When one goes bad, it effects the stability for the other parts to function properly, so replacment of all is best.
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
SOURCE: fridge not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
