To arm content theft alarm. 1. Open the door. 2. Lock the door with the power door lock switch or the remote keyless entry transmitter. The SECURITY light should flash. 3. Close all doors. The SECURITY light should go off after approximately 30 seconds. The alarm is not armed until the SECURITY light goes off.
If a locked door is opened without the key or the remote keyless entry transmitter, the alarm will go off. The headlamps and parking lamps will flash for two minutes, and the horn will sound for 30 seconds, then will turn off to save the battery power.
Solution: Elect lock activator inside door either weak or is binding not pulling lock all the ... Right passenger door wouldn't open from outside, then my kid turned on the interior ... civic door won t open from inside or outside fix no drilling ... Has recently started to just suddenly lose power and stop but i can start it again and it ...
Tesla MotorsFor some reason, the passenger side front door will not open when pulling on the handle. We have the tech ... There's nothing you can do to fix it yourself. ... I tried locking and unlocking it at the restaurant and that didn't work so I just opened it from the inside. ... Handles extend, lights work, but I can't open from the outside.
Chances are the autolock doesn't work because it "sees" a door open. Check the plunger between the door and the frame of each door to see if the plunger is broken, bent, or otherwise not working.
so you start the car and the radio will not work? but the radio works with he door open and key off? its normal to turn the car off and the radio play until you open the door.
It sounds like your Power Door Lock Relay is working intermintently. Bypass the relay and test the Power Door Locks with a jumper wire direct from the battery, if they work with no hesitation then it is a bad relay.
THERE IS A VALET SWITCH TO OVERRIDE THE ALARM. PUT THE KEY IN THE IGNITION AND TURN IT,HOLD THE BUTTON(USUALLY A LITTLE BLACK BUTTON UNDER DASH) AND CRANK ENGINE OVER. THIS WILL START THE CAR AND CUT ALARM OFF
