After i installed the cracked version of fifa 2002 it says' pls insert cd'.how do i fix this problem
Buy a cd key from https://www.m8x.com, you can make it, or you will not get the license to play the game, games gold and games items also available there, you should have a view there, good luck to you
You're not supposed to pirate games.
SOURCE: AFTER FULL INSTALLMENT OF FIFA08 THE SYSTEM IS GIVING MESSEGE LIK
For this u need to ve a image file...Just write the exe file of fifa08 in NERO..In the drive field select Image Drive in NEro and save the file in some location...after that mount the image in Daemon tools and run...The game ll work.....
pls rate my suggestion....
SOURCE: I installed the game..but whenever i try to open
first you have to go crack folder of that game disc, after open that
crack folder you have to copy that game.exe file, and then you have to go
the game directory where you have installed that game, there you have to
paste that, they will ask you to replace, then you click on "yes"
button. now you can play that game easily....
thank you
SOURCE: no disc inserted problem
i have installed crashday and also copied and pasted the exe file inthe place where the game has installed but still its asking to insert the cd or wrong disk inserted. please help me.
