I have a risograph( Rn2100 ep ) that prints about 20 sheets & be stopped & error . I replaced a new ink & cleaned evry things but it does not better. please help me . thanks
It sounds like you are experiencing an issue with the red ink drum on your Risograph MZ1070E printer. The error code t44-513 can be caused by several factors, including a clogged or dirty ink drum, a faulty ink pump, or a problem with the ink sensor.
Here are some steps you can try to troubleshoot and potentially fix the problem:
Clean the ink drum: Use a damp cloth or cotton swab to gently clean the ink drum. Make sure to remove any debris or dried ink that may be clogging the drum.
Check the ink pump: Make sure that the ink pump is functioning properly and that it is not clogged or damaged.
Check the ink sensor: Make sure that the ink sensor is functioning properly and that it is not clogged or dirty.
Check the ink supply: Make sure that there is enough ink in the supply and the ink is not expired.
Check the ink filter: Make sure that the ink filter is not clogged or dirty
Check the ink drum unit: If the issue persist, you may need to replace the ink drum unit
Consult the manual: Consult the manual for specific troubleshoot and service information for your Risograph MZ1070E model.
If you are not familiar with these tasks, it is best to contact a professional or Risograph customer service for help with diagnosing and repairing the problem
All you really have to do is put in the ink color you want and run a bunch of prints. Going from a light to dark color like black is fast--like about 3000 prints. Black to light color is going to be a lot more prints. Best is to print something with heavy ink. the more ink you put out the fast it will change color.
Reset the printer & copier, according with your owner manual. Please make autodiagnostic, read your owner manual. However if the problem persist, go to website from your supplier and get support free via ONLINE chat. God bless you
The document specs of your printer is given below:
Document & Media Handling
Max Original Size
Legal (8.5 in x 14 in)
Original Type
Sheets
Min Copy Size
3.5 in x 5 in
Max Copy Size
Standard Media Capacity
100 sheets
Output Trays Capacity
50 sheets
Document & Media Handling Details
Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in
I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert backSuspected 1) paper scanner faulty not able to judge paper.
First make sure there isn't any thing keeping the carriage from moving freely, the reset as follows: How to clear Error Code Canon printers MP150 MP160 CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF) E3-3 Paper jam E4 No ink E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks
0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset See waste ink counter reset procedures below. 5 times Orange Destination setting See Destination setting procedures below. 6 times Green Print head deep cleaning 11 times Orange Button / LCD checking 12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
You can clean it, thats a good idea but,,(and this is messy) roll back the master.. take out the ink cartridge, use a rod to squeeze some ink onto the area, and smooth it out into the screen with a plastic scraper.. Lay the master back over. Keep scrap paper around and print a big black square and run a couple hundred sheets through.. This will work. Messy but will work. If you don't want to manually put some ink on the area.. Print a large black square and run a couple hundred sheets.. see what that does.
lol.. there's no thermal head on a Riso..lol..
Ok..Print a big black square and run the machine maybe 300 prints until it starts pushing ink through, set the machine on darkest setting.. The ink in the screens is just old and sticky.. If you go through a case of paper (5000 sheets) and it still isn't getting better then take off the master and use some varsol and a lint free cloth (LINT FREE!) to dab and clean the whole screen to loosen up the clogged ink.. If that's not working then you really have to take the screen off and clean it first with varsol,, then some soap and water.. You have to be really clean about this because lint or any thing will cause white dots on your print. (hey this happened to me) If you've cleaned it really well you should take a clean scraper and prime the screen area with some fresh ink.. this is messy.. but it will get you going for good..
