Scanner error 8
SOURCE: M2727 MFP no lights on the display
probably a cable is loose or not connected for display. printer could be faulty or you mught fix easily.
SOURCE: my hp M1522nf printer is giving a scanner 8 error
Is this device still under HP Warranty?
I hope so.
Several HP models have Scanner failures, which require the Scanner replacing...
Try to find this Part no:
CB534-67903
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
SOURCE: I cannot print or copy
Hello, This sounds like a Scanner/Flatbed Problem. This series of printers have a known problem
with this component. The scanner is failing to initialize itself. The scanner
does need to be changed by an Authorized HP Warranty Repair Facility. It is
possible that it may be covered under an HP Extended Warranty program. See
repair information VIA posted Link.
Cheers!!
SOURCE: i have an hp m2727 with a scanner issue,, after
This type of failure usually will cause a Scanner 5 or 8 error on the control panel but not always. HP has a Service Advisory that will cover any unit manufactured before January 1, 2010. Contact HP immediately as this advisory expires soon. Any HP service partner can fix this for you but I have found that many do not even know that this advisory exists. Be insistent, this is a more common problem than HP will admit
Expiration: 2011-03-23
CC370-60001
Formatter - LJ M2727 model
CB532-67905
SSA PKG FGI ASSY (scanner flatbed
assembly)
Cheers!!
