Question about RCA RCR311B Remote Control
How do I input the codes for the RCA remote? - RCA RCR311B Remote Control
Rca universal remote code for sanyo tv?
The codes are the TV not the remote, so here are the codes I show for he Sanyo TV. You will need to just keep inputting them until one works. I would try the "Code Search" function of the RCA remote first.
Sanyo Remote codes: 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
Feb 07, 2017 | RCA Televison & Video
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
Apr 16, 2013 | RCA L32WD22 32 in. LCD HDTV
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
Codes to make Sony universal remote rm-vz320 control my RCA 46LA45RQ
For mine the rca listed code 00178 almost worked (no movement during input or menu)
Code search found 01265 which works all the buttons I use.
Dec 05, 2012 | Sony RM-VZ320 Remote Control
How do I change the input so I can use the rca jacks in from the tv with the remote I have a salvania .
You are asking about the input selection of the tV, by using a RCA universal remote I assumes and posts this solution. All setup codes fro a tV with remote control might not work with all functions as it meant to be. Try an other setup code fro your TV with your remote. There is no other way than this. Universal remote codes for Sylvania TV are:
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Jul 04, 2012 | RCA Universal Remote Control
Need code for a rca remote for a seiki tv
You should look up that code in the manual of your RCA remote.
Seiki doesn't appear in the manual? You should follow the procedure indicated when a device is not listed with code.
You don't have a manual for your RCA remote? Please indicate the MODEL of your remote so someone might look it up on line.
Actually, if you input terma RCA, the model and MANUAL probably you can find it yourself.
Feb 07, 2012 | Televison & Video
Prgram old RCA removte
I also have an early RCA universal remote with the number 97P04730 stamped on the battery cover. I do know if that is the part number for the remote. There are buttons labelled TV and VCR, presumably to select which device the buttons will work for. This remote has a "search" button, but no "code search" button that is found on later RCA remotes. I have spend several hours searching the net for any information on this device. The only thing I found was a post that claimed this early remote is programmed by pressing and holding the device button (TV or VCR) and simultaneously entering the device code. Because this is a very old remote, it probably uses 3 digit codes. There are several places that list RCA 3 digit remote codes. I have tried to program mine this way, but I have not been successful. Possibly my remote is not working correctly, but it is putting out IR.
Jan 29, 2012 | RCA Universal Remote Control
How to program an RCA RCR450C. I also need codes for a tv Hitachi 27SC48 adn a Magnavox CCR136AT02
The REAL solution. The link below is the manual to the RCR450. It shows a pic of the remote which is exactly like the RCR450C. This will teach you how to program the remote and it gives you the codes for the different types of equipment for the universal remote. When the web page comes up, click on "click here" that is in red. Save this manual in your Adobe files for future reference.
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Jan 07, 2009 | RCA RCR450 Remote Control
RCA RCR311B Remote Control Logo
67 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
