Question about Linksys Cisco Small Business WAP4410N WirelessN Access Point PoEAdvanced Security (S7271261)
What is default IP of CISCO WAP4410N WIRELESS ROUTER
    Guru:
  • 147 Answers
Hello Anonymous,
The default IP address for the router you are asking about is 192.168.1.245.
The user manual direct from Cisco can be found at the link below.
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdf
what is default IP of CISCO WAP4410N WIRELESS ROUT - 24606349-ploq43q5ggricewjpqkykky4-5-0.png
Take care and have a wonderful night! -Alex K
Posted on Nov 30, 2014
3 Suggested Answers
6ya staff
SOURCE:
Quick-Tech
Shaun Harris
  • 83 Answers
SOURCE: How do I reset WAP4410N router back to factory
There should be a reset button to the right (the back facing you) of the antennas on the back, press that for 10 seconds to restore back to factory default. You may also go into the the web based control panel of the router and set it back to default.
Posted on Dec 06, 2010
jwiggins8579
SOURCE: I'm trying to configure my
Network settings on your computer
right click on lan network and properties go to ipv4 properties and use the following.
IP address 192.168.1.2
255.255.255.0
router defaut in the default gateway settings (mine was 192.168.1.245)
enter that again in the dns primary (dont worry about the secondary)
plug an ethernet cable to your wireless router and type in the default gateway.
that will get you to your logon page.
hope that helps
Posted on Jan 11, 2011
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
Configuring cisco wap4410N
Configuration? What type of configuration / settings would you like to know? Anyhow , just use the link below and it will redirect you to the page of your Cisco Service Manual, where you can see the complete image instruction /setup / configuration of your cisco wap4410N
I am sorry , for the answer that I provided . Since I dont have an idea for the configuration that you needed much better if your going to use the link that provided because its very helpful thanks
Mar 18, 2014 | Cisco Computers & Internet
How to connect wap4410 with pc to confgure
Try disconnecting your Cisco Wap4410 from all other network devices then restart it - it will look for a DHCP server, and when it doesn't find one will choose the IP: 192.168.1.245 ---
Set the TCP/IP settings on your laptop to:
IP:192.168.1.250 / Subnet Mask: 255.255.255.0 / Default Gateway: 192.168.1.245 and connect your laptop ONLY to the WAP4410 using a cat5 ethernet cable ---- you should then be able to load a web config page using internet explorer and browsing to: http://192.168.1.245
-------- I've paraphrased the following info from the Cisco User Support Forum (User Juunda):
"...If you read the administrator guide it states that the WAP4410N will search for a DHCP server first, if the dhcp request times out then will it default to 192.168.1.245 this is done so with a user friendly plug and play mentality in mind. Best practice would be to give the AP a static IP of your choice and in your subnet/network so the fastest way to configure the AP out of the box is to assign a static IP on your pc/laptop in the 192.168.1.X /24 and directly connect to the WAP4410N and give the WAP a static IP, define your gateway, DNS servers and then implement it into your network..."
Sep 06, 2013 | Linksys Cisco Small Business WAP4410N...
Linskys e1000 reset and password
Hello from here you can download a manual:
http://homesupport.cisco.com/en-us/support/routers/E1000
You need to install Cisco Connect software.
To reset it you have to press a small button at the back of the router
With power on.
E1000 Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Good luck
Oct 29, 2012 | Cisco Linksys Wireless N Home Router...
Configuring Wi-Fi Protected Setup
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 24, 2012 | Linksys Cisco Small Business WAP4410N...
My cisco wap4410n won't let windows 7 connect
Dear Romo
i have had lot's of problem with the WAP 4410N
the usual solution was to reset the Access Point
and in some case you have to reset it to factory default and set it up again try change the channel of change the location of the Access point for testing only
yesterday i face a problem with WAP4410 that the laptop gets IP but smart phone /tablet doesn't connect stack when getting an IP with static IP the devices connected
So what i did ,I went to the market and buy a new AP NOT Cisco brand
Cisco devises i lost truest on it
Abdullah Al-Ahmadi
System and Network Eng.
Mar 26, 2011 | Cisco WAP4410N (WAP4410NLA) Pre80211n...
How do I reset WAP4410N router back to factory defaults ?
Dec 06, 2010 | Linksys Cisco Small Business WAP4410N...
I'm trying to configure my Cisco WAP4410N Wireless-N Access Point and i cant access the login page to do it. My IP is already set to 192.168.1.# so i thought i would be fine but it still doesnt work
255.255.255.0
hope that helps
Nov 03, 2010 | Linksys Cisco Small Business WAP4410N...
Linksys Cisco Small Business WAP4410N WirelessN Access Point  PoEAdvanced Security (S7271261) Logo
322 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
