A
Anonymous Posted on Jun 10, 2014
4500 Phaser -What causes black dots left side of page?
Our Xerox Phaser Printer is causing faint black dots down the left side of the page, about 1-1/2 inches apart, evenly, all the way down the page.
Dave Smith
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 21 Answers
  • Posted on Jul 03, 2015
Dave Smith
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
21
Questions
0
Helped
11344
Points
29
Sounds like something stuck on a roller with a diameter of ~1/2" diameter.
Good luck.
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on May 30, 2008
SOURCE: Xerox Phaser 8400 Streaking
You can go into the trouble shooting menu and do the "eliminate Light stripes" procedure a few times.
Then you can do Jet substitution from the same menu.
If that does not work then most likely you need a new print head.
If you have used non xerox ink sticks that is your most likely cause of the problem. cheaper is not always better
Anonymous
  • 2072 Answers
  • Posted on Jul 12, 2008
SOURCE: phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Anonymous
  • 679 Answers
  • Posted on Jan 07, 2009
SOURCE: Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Anonymous
  • Posted on Mar 18, 2009
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Anonymous
  • 2072 Answers
  • Posted on Jul 16, 2009
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
Faded black and white printouts
If you remove the toner cartridge and gently shake it side to side, then reinstall it, does the problem go away, or come back after a few pages? I would suspect you have a bad toner cartridge/image unit and recommend you put in a new one.
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
Repeat this procedure for the other pages.
Our Xerox Phaser 4500 printer has printer cooling fan error. Call Service - Code U5
U5 00 SPF COMMUNICATION TROUBLE
U5 16 SPF FAN MOTOR TROUBLE
U5 30 SPF TRAY LIFT-UP TROUBLE
U5 31 SPF TRAY LIFT-DOWN TROUBLE
U5 40 SPF INSTALL TROUBLE
For more help visit cbr tech solutions
How do you add this printer
You may refer the page http://www.office.xerox.com/printers/laser-printers/phaser-4500/enus.html and clicking 'see how easy to install'
Kindly let me know if you are not able to install.
Thanks
1helpful
1helpful
I have phaser 8400 with 40k page count. I am getting a mark on page about 6 inches from top of page and 1/2 inch from left margin. Sometimes it is a faint blur 1/4 inch wide and 1 inch long. Other times...
Run Remove Ink Smears from the Troubleshooting menu. Try running the jetfix snippet found on Xerox website under downloads. It sounds like you may have a defective printhead telling it to spit out some magenta ink at the wrong time.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
