SOURCE: sony cdp-cx355 cds skip only on tracks 1 through 5
I got a free one of these from my work...well that is because it was having the same problem and they didn't want to mess with it haha. Sooo...I brought it home..thinking i could just buy a cd cleaner kit and clean the dirty lens..which is what normally causes these problems. To my dismay this didn't work (later found that the lens is a good half inch away from the disc)..so i decided to open the bad boy up (hey I got it for free...no harm crackin it open :-) ) After hitting the lens with a can of air..I tried again...no go. And just so you all know...this player runs vertically..not horizontally. I want to know how does the player read? the lens in stationary. All other players i have seen the lens moves up and down. I'm thinking it might have something to do with that. I gave up on cleaning it and started doing some searches..this was the only forum that was somewhat helpful. I agree with Silverscreen. When i watch the cd's playing the disc wobbles SLIGHTLY up and down. I think the rear stand-alone wheel is a bit too loose. ..The amount it wobbles is hardly noticed but is the only thing i see out of the ordinary.
SOURCE: My Sony MegaStorage CDP-CX455 400 Disc changer
Pretty much the only thing you can try at home is cleaning the laser lens, if the cleaner works then remember to use it now and again.
If the CD lens cleaner does not work the take it to the nearest sony tech/dealer for repair. Multi CD systems are very complicated and need specialist attention.
Hope this helps
Thanks for using FixYa
SOURCE: Sony MegaStorage CDP-CX355 300-Disc CD Changer
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it is refusing to play any more CD....
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens. You can add very little liquid to the cotton board like mentholated spirit and dry the lens with another cotton board that has not liquid on it.
If non of the above solves the problem, then it means the lens is weak beyond cleaning. Know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all CD's again without any problems.
I hope you understand the above.
Regards.
My CDP-CX355 needed a new belt, so I used a rubber band. It works fine.
What size of rubber band?
