Check the gas line that is in the fuel tank . It has a filter on it and if its not down at the bottom of the tank where it should be then its not getting the gas it needs. If you tip it the gas may be too low for the hose to pick up. The hose needs to be on the bottom.
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-eddiaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
