HP LaserJet 1300 Printer Logo
Seun Adelaja Posted on Jun 10, 2014
Help my hp laserjet 1300 is showing all the light on
I need the service manual as well
5 Related Answers
parkerguy
  • 138 Answers
  • Posted on Aug 04, 2008
SOURCE: HP 1300 LJ Fuser Film
If you didn't have the orange light to start with and were replacing the sleeve due to a torn or damaged sleeve it sounds like you haven't plugged everything back in. The Error is an electrical fault with the fuser circuit.
Verify that all wires are plugged back in. Two areas to pay specific attention to are as follows. (1.) BOTH slide clips witth wires that you removed on the upper fuser edges to mount the new sleeve. Thats the connections for the ceramic element. If you get to having to uninstall and check the fuser, put an ohm meter on both ends of the element to ensure it's not shorted. My meter when on ohms has a beep when the leads are touched together when the meter is measuring ohms. Check for the beep when touching both ends of the element and that will prove the element good.
(2) On the board in the base of the machine, there are some plug in connections on the lower board very close to the rear edge and just about centered left to right. It's a cluster of about 3 or 4. Unplug the connections and pay close attention to the height of the pins inside the connection. One of those connections has a nasty habit of the pins slidding through to the other side and not making good contact. If I remember right its the right hand connection in the cluster or the one next to the right one. You can use the connections rest to it as a visual referance for the height. If the pin or pins have pushed down, carefully pull them back up with needle nose pliers or tweezers and replug the connection back in.
Hope that helps you. Just in case, heres a free manual PDF link to use to resolve. It's a 1200 manual as the 1300 wasn't listed but the processes are identical. Most of the parts are the same but check first before ordering any parts.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%201200%20Series%20Service%20Manual.pdf
Anonymous
  • 859 Answers
  • Posted on Sep 29, 2008
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
Hey look, sorry for all the BS you've been given. Its an issue here.
How much ram does your laser jet hold right now?
This would be the choke point on an HP laser jet.
A typical PDF file in high res can be many many megabytes in size and the HP Laser treats these documents as an image file, same in true in Windows, but uses local ram not printer ram like an Apple.
So, if you have a 256K chip, its possible, on your printer and the file is 4-6 MBs in size, you could be looking at a 16-20 minute print job.
I'm not familiar with any tricks to get your printer to use local ram as a cache. If you have Boot Camp, you might consider starting that emulator up and printing from that interface. No real hope for a difference but its worth the try.
Hope that give you some real thoughts to chew over.
Regards,
Worldvet
Anonymous
  • Posted on Dec 09, 2008
SOURCE: HP LaserJet 1300 is showing blinking of orange light instead of tonner is in
I am having problem in finding solution for HP Laser Jet 1300 which is not getting ready and shows orange light blinking. I have check the tonner and the sensor which are located backside but the problem is still as it.
Anonymous
  • Posted on Mar 11, 2009
SOURCE: Free HP LaserJet 1300 Printer Driver
i don't have priter driver for HP Laser Jet 1300 printer, can i download it, how to download it?
A
Anonymous
  • Posted on Mar 17, 2009
SOURCE: HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Help my hp laserjet 1300 printer is showing all the light on
www8.hp.com/us/en/support.html
Service manuals are written by the manufacturer.
No power at all
Try to leave it unplugged overnight and try to use a different power cord. Also, here is repair manual for your device.
Maybe it will be useful for you. HP LaserJet 1150 LaserJet 1300 service manual repair scheme download...
I wont a hp laserjet 1300 drive to install in my system
Here the driver download page:
See also below on how to install the drivers:
Setup, install, and configure
You can also download the manual here: Manuals
How to get the printer driver,
Here some helpful link.
To download drivers and software:
12helpful
6answers
Installer of hp laserjet 1300
dear all
i need install of laser jet 1300 printer urgently
please help me
7helpful
3answers
2answers
HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
84helpful
11answers
k24674
Grand Canyon Tech
Grand Canyon Tech
