How do I change out the Switch on a gas cook top -Jenn-Air JGC9430ADS
if you mean the switch under the knob,
you can open up, drill, the switch and clean up and use it again, uless the copper parts are burned out.
to get to the switch, most likely have to unscrew all the screws holding the top and the bottom together, most likely the screws will be on the top, by the gas burner on each burner. and may need to check the sides for additional screws .
if you go step by step , its pretty easy.
maybe you should look up on you tube for demo.
