Tablets & eReaders Logo
C
Calvin Henry Posted on Jun 11, 2014
I need driver for piranha ultra II tab 7.0 compatable with windows 7
  • Peter Dragonetti Jun 11, 2014
    Hi Calvin Henry, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? wich driver do you need ?? and for what device ??
Martin Buenrostro
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Dec 17, 2014
Martin Buenrostro
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
6885
Points
28
You don't really need driver's to transfer file, pic, doc, movies,etc...
just connect the Mini USB cord and on your tablet's notification area make sure you select USB connected.> select USB connect and the android will turn Orange.
You will see Drive E :(that will be the Tablet's Hard Drive Storage)
and F: (F) drive will be your external SD-card storage.
Is a samsung galaxy tab 4 7.0 compatible with straighttalk ?
It depends on which model of the Galaxy Tab 4 you have. The unlocked Galaxy Tab 4 3G is compatible with the Straight Talk GSM network and has a SIM card slot. There is a Wi-fi only model which will only talk to a cellular network through a hot-spot device.
I hope this helps.
I am try to get the download and driver but it can't find my S/n number
For a driver you don't need a serial number. Most of the time you even don't need to download anything.
The drivers, made for older windows versions, won't work on a Windows 7 or Windows 8. Not even in compatibility mode. Microsoft needed to make Windows more secure, so only allows drivers in there modern operating systems when they have a Microsoft certificate. For a certificate the manufactures must use Microsoft protocols, ask Microsoft for certification, and pay for the tests Microsoft does, to check the software is working correct. So no manufacturer will ask for certification of drivers for hardware they no longer sell.
Long story, but unless you can write your driver yourself, or you can find an universal device driver (not sure something like that exists) you won't be able to use the device.
I saw some dodgy sites trying to offer drivers. Be aware all drivers you can install in windows 7 or 8, you can get them from Microsoft. The ones you could use on an XP computer can't be used, because Windows 7 or 8 won't let you install them. Just for security reasons.
When your device is sold with compatible with Windows x and it is lower version then the one you use, most likely you can't find driver for your device for the modern Windows. Almost no manufacturer will offer drivers for hardware they no longer sell. Success
1helpful
Where do get drivers for zeepad 9?
When you connect something to an USB port for the first time, don't hope to much. You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
2answers
Can i get help with my tc1100
The official site for download of all TC1100 tablet pc is available at this link.
HP Compaq tc1100 Tablet PC
These drivers are compatible only for Window XP. If you are trying Windows 7 then you will have to take a chance. It may or may not work.
See this article.
HP TC1100 Windows 7 Installation Notes
Want to know the dell streak 7 specification
Technical Details
  • Android 2.2-powered mobile tablet with 7-inch multi-touch display loaded
    with entertainment and multimedia apps
  • Enabled for T-Mobile's ultra-fast 4G network; Pay as You Go with prepaid and
    monthly data plans
  • Rear 5-MP camera for photos and video; front-facing 1.3-MP camera for video
    chats via Qik service
  • Ultra-fast Wireless-N Wi-Fi (with Wi-Fi sharing); Bluetooth connectivity; 16
    GB memory; microSD memory expansion; multi-format media player
  • Up to 4 hours of video playback, up to 72 hours (3 days) of standby time;
    released in January, 2011
> See
more technical details
Product Features and Technical Details
Product Features
    monthly data plans
Dimensions
  • Size (LWH): 7.48 inches, 4.74 inches, 0.47 inches
  • Weight: 13.44 ounces
Product Features
  • Network Compatibility: GSM
I don't know if this is exactly what you are looking for, but it's a starting point :)
Bluetooth and wireless not work on windows 7
Your bluetooth and Wireless Lan is not working because Windows 7 is not compatible with this devices. And unfortunately, you cannot find any drivers for your tablet PC that is compatible with windows 7.
Go to this site to know what Operating Systems is compatible with your Tablet PC . CLICK ME
So I suggest that you change your Operating System so that your Bluetooth and Wireless Lan will work perfectly..
If you need drivers for your device. Just click the link above, and click on the Operating System you are using. (Except windows 7)
Goodluck, Hope my solution helped. Thank you for using Fixya.
I own a gateway M280 convertible laptop designed for windows xp, tablet pc edition.I tried installing windows xp sp2 but it didnt find any hard disks installed on my system.i finally got another os called...
if your installing windows 7 it will have all the touch screen drivers and such already built in, just a matter of enabling then in your control panel
I need wireless drivers as i am not able to connect to my wreless network. Can you help me to configure to the wireless neetwork Model: Itronix Duo Touch II
the link below will take you to the General Dynamics driver page.
Just select your model and operating system. The WLAN drivers are located in the intel chipset exe as they're the integrated intel ones not a 3rd party
note: windows 7 not supported on Duo-touch II, I had to go back to vista business as I lost funtionality with the buttons and was unable to change resolution above 800 x 600 due to lack of Intel video driver
1helpful
Hi, I have a HP G72-259WM Notebook Pc, Windows 7, how do I find a printer that is compatiable with my computer,I have 2 printers that I can't use, because this computer does not support these printers
If it has usb ports ( which it has) and running windows 7, it should support almost any new printer.
Epson sx series are great cheap multifunction devices, plus epson compatable inks are very cheap
Have you looked for windows 7 drivers for the other printers??
Top Supersonic Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Supersonic Tablet and eReader Expert? Answer questions, earn points and help others
