Question about Mach Speed Trio Stealth G2 8 inch Tablet with 8GB Memory
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
The tablet turn on and said trio stealth g-2 then change to other screen and said @9 Dual Core and that said don't want to move to the next screen I just one to know what happen with the tablet
  • 1 more comment
  • SKY IBARRA
    SKY IBARRA Aug 07, 2014
    have u fixed your tablet because i have the same problem but mine is stuck on the loading page please tell me if you have fixed it and how i will really appreciate it thank you
  •  Gary Gemmell
    Gary Gemmell Jan 27, 2016
    There should be a pinhole reset button - try tht first!
  • Brandon SPCleister8102 Leister
    mine does not work with the Hard reset it just says treo stelth g2 screen and no recovery screen and i have a bad battery and the charging cord can that be a cause?
    Sergeant:
  • 261 Answers
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Posted on Jun 12, 2014
2 Suggested Answers
Anonymous
SOURCE:
russ_hill007
Russ Hill
  • 4057 Answers
SOURCE: serial number for trio stealth g2
on the box also there should be a number on the back of the unit.
Posted on May 28, 2014
Testimonial: "There was no number on the box. there was a lot# that rubbed of almost immediately. So that is gone."
Get my tablet to get off the @9dualcore screen?
Have you tried the reset method below?
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also I've learned work on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned as well. But.... TRY AT YOUR OWN RISK. Here it is.
(1) PRESS AND HOLD the power button until the tablet shuts off completely.
(NOTE:
if any type of start-up screen comes on, FORGET it: the Tablet must be COMPLETELY powered off for this to have any chance of working.)
(2) PRESS AND HOLD the volume-down button, while simultaneously PRESSING AND HOLDING the power button
This will (hopefully) bring up the Android figurine, along with some kind of rotating-wheel graphic.
(3) Do nothing else but WAIT, until the screen changes to a text-based menu, with about 6 to 8, or more choices.
(4) Use the volume-up and volume-down buttons to navigate between choices, and select (highlight) the choice offering to reset the tablet (to Factory Settings).
(5) Click and release the power button to start the reset operation. Follow and additional prompts to ensure you are selecting the correct next step.
This RESET process will erase ALL your installed apps, as well as delete all your saved photos, music and other user files and preferences (including wallpaper, time-zones, Wi-Fi settings etc. But when it works it will give you back a working Trio. Use your reset Triot carefully: generally, I'll say the Trio machines are good economical alternatives to the perhaps more robustly engineered (and much more expensive) big brand items.
Regarding restoring personal preferences, and earlier installed apps I have no experience whatsoever. However there may be sufficient arguments to backup your personal data either on your home computer or on online "cloud based" services. Do the research, ok?
Happy New Year, 2015 ... & ....Good Luck!
Dec 07, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
My trio stealth 10.1 is getting stuck on the@9 dual core load up screen. what do I need to do to get it to finish loading??
HI Naomi.
I do alot of TRIO fixes. Here is a great youtube walk thru. If it does not work I can try some other fixes but they can wipe out all your settings and data.
Good luck
Chadman TRIO 10 1 g2 Stealth Elite Android Tablet Update 2 Testing Recovery Mode...
Nov 24, 2014 | Tablets & eReaders
Trio 10 1 turns on but wont go past the next screen to see my apps
Press power and volume + buttons together until reset screen comes on, then select factory reset!
Nov 09, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
My trio stealth -9 shows first screen with that on it next screen shows@dual core then it want do anything else what and how can I fix this
Hi, try to connect it to your computor, and try to access....if nothing, then you will have to do a software redo.....
Jun 21, 2014 | Tablets & eReaders
FREZZES ON THE 9 DUAL CORE
Hi:
Try my generic fix for tablets. Press the on/off button and at the same time, press Volume+ button. Seems to have worked for many people. If it doesn't you may have a virus or you may have to try and reset it back to when you first got it. Hope my generic "freeze" fix, works.
LindaSView
Apr 02, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Tablet won't turn on or get to wi-fi
mine did that too you have to reset it from the back. and the wifi you might be putting the password in wrong thats what happened to me
Jan 31, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth-8
I fixed this triple screen issue by opening the unit (2 screws, then slide fingernail around the edge), then reseat the video connector (it's the largest connector), flip up the locking tab, then reseat the connector & flip the tab back down. Test it, then close it up.
Jan 19, 2014 | Tablets & eReaders
Mach Speed Trio Stealth G2 8 inch Tablet with 8GB Memory Logo
653 people viewed this question
Top Mach Speed Tablets & eReaders Experts
yobo007
yobo007
 Russ Hill
Russ Hill
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
