Televison & Video Logo
What is the remote codes on sony universal for l46fhd37
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
  1. Turn on your Sony DVD player.
  2. Locate the code for your Sony DVD player in the code list provided with the universal remote.
  3. Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
  4. Enter the code for your Sony DVD player using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
  1. Turn on your Sony Bravia TV.
  2. Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
  4. Enter the code for your Sony Bravia TV using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
How can i program my vizio tv , to my sony home theater remote?
Make sure to hookup and power on all the Sony TV or other device you want to setup using Sony universal remote codes. next, make sure the batteries are working in the universal remote. Note down the Sony universal remote codes from the list provided. Nothing is more frustrating to find out that you have not hooked up or universal remote batteries are bad after spending your evening on trying to program Sony universal remote.
step1
Turn on the component to be programmed.
Step 2
On the remote control, press and hold the SET button until the SET indicator lights up.
Step 3
Press the appropriate component select button for the component being set up.
Step 4
Using the number pad, enter the component's manufacturer code. Note: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
Step 5
Press the ENTER button.Point the remote control at the component and press the POWER button.d out that you have not hooked up or universal remote batteries are bad after spending your evening on trying to program Sony universal remote
Codes for sony blue ray dvd
Sony Blu-Ray Universal Remote Codes
  • 5 Digits Universal Remote Codes For SONY BLU-RAY. 42178. 11516. 42180. 41516.
  • 4 Digits Universal Remote Codes For SONY BLU-RAY. 2014. 2020. 2484. 2113. 2226. 2251. 2273. 2257. 2171. 2108. 2065. 2162. 2244. 2309. 2355. 2407. 2406. 2329. 2313. 2306. 2305. 2296.
  • 3 Digits Universal Remote Codes For SONY BLU-RAY. 670. 671. 644. 617. 730. 768. 729. 731. 645.
2helpful
2answers
I need the 3 digit code for ge universal remote model RC24912-A for sony dvd player
Code lists and manuals for GE remotes are available from http://www.jascoproducts.com/support/universal-remote-codes.asp . The 3-digit code list is here: http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit.pdf . The Sony DVD player codes to try are 166, 320, 321, 322, 361, 389, 399, 909 . (Sony DVD recorders may use 302, 321, 322.)
However, the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a newer universal remote.
I hope this helps.
Code for rca television model l46fhd37 vs videotron remote
What you can do is turn on your TV, then press the search /code press 3 times if it blinks you got a connection from your remote.. no need code this auto search code search got a purpose
24helpful
2answers
NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
2answers
I need the code for a Philips SRU3006WM/17
Codes listed for Sony DVD players are 0300,0400,0500,0541,0200,0540. Hope this helps due to no listing for Blu-Ray players.
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
