Frozen with picture still on monitor and tried all buttons but nothing works
SOURCE: camera frozen
(1) Load your camera with a freashly recharged battery.
(2) Switch on to see if it's working and still without the real time screen.
(3) Switch it off, and hold it tight in you palm with the LCD facing inward.
(4) Now, with you palm up, you should be able to see the model name 'CoolPix S6' under the lens and the flash.
(5) While holding the camera and aiming at the 'CoolPix S6', raise your other hand with the fist next to your ear.
(6)
Match the aim as describe in(4) to the aim of your elbow 's protruded
part and make pratice moves. Yes, you'are going to smack it
to your elbow.
(7) When you are ready, try first not to hit your elbow too hard once.
(8)
Switch the camera on to check. If you have the 'Screen' now,
congratulation! If not, repeat (4) to (8) but with a stronger impact
Force. You might have to try more times until your elbow could not take the sore.
SOURCE: r09 shows up when I try to take a picture. Cannot access preview screen. Camera seems frozen.
This means Bent lens lever. Gently straighten it or get it replaced.
